Headers that will fit a 4R70W
904Bronco
San Martin, CA
One of the guys that I did a 4R70W swap from a 5-spd manual wants to do headers and a dual exhaust. (From a 2 into 1)
WH's JBA made headers, don't fit, and I have told him so. Nor am I willing to do all the mods that are required to bend the factory Explorer Trans dipstick tube and cooler lines to clear the header flange that practically sits on the bellhousing.
So does anyone have any practical experience with another brand of header that clears the 4R70W bellhousing, along the dipstick tube/cooling lines? I can guess that if it clears the bellhousing, it might have clearance issues elsewhere, like the inner fender...
This is a 5.0 motor with Mustang EFI.
(Pic's from Clifford for reference below)
badandy73
Broncoholic
That's strange, I was able to use the JBA/ WH shorties without major issues.
Passenger side was tight but just had to trim one of the cast tabs off the case of the trans and bend the Hughes dipstick a bit to clear.
Boss Hugg
Look into headers for a 64 falcon. Thats what I’ve been running since I went to fuel injection. They weren’t made for gt40p heads, but I cut a couple tubes loose from the head flange and stretched them out to create the room I needed. Soon I’ll be going to the Sandersons because I think I’ve got some leaks developing dude to rust in the unfinished headers over the years. They amought to work of the OEM heads fine.
Bruners4
1/2 way to everywhere
I have a set of Tom's coated long tube headers that have been cut and turned to clear the 4R70W in my Explorer swap. But the Atlas is in the way for the driver's side outlet. They have been run just long enough to move it around until it arrived at the Exhaust shop. PM if you want to know more.
I installed Scott Drake mid-length headers without any custom work.
904Bronco
904Bronco
San Martin, CA
Yeah, I'm familiar about the casting tab needing cut off.
I purchased the Hughes dipstick, but at $55, I wasn't ready to start bending it up. I stayed with the Explorer factory tube.
widowmaker77
@904Bronco so this may or may not help you…but I’m running a 4r70w and I’m using a factory 94 f150 dipstick tube with no mods. Clears headers and firewall . Extends up to just under where my intake tube is running for my explorer efi. I’m running toms long tubes but I did have to pie cut the collector on the pass side and bend it towards the frame rail.
PaveBronco
I’m running Duffs 2 into 1 kit that came with shorty headers (Duff/Drake) on my Explorer/Mustang EFI.
Clears the 4R70W, had to trim the bell housing casting tab and notch one of the flanges (cant remember which one). I ended up doing a lot of OCD cutting and welding the exhaust tubing to get it where I wanted it. I’ll post some pics if that will help. I have a flexible dipstick, so cant speak to that.
904Bronco
904Bronco
San Martin, CA
Thank you all for the replies.
I am sharing them with the owner, he is a little slow to comprehend as he is Bronco driver, rather than someone who wrenches.
It has been an education for him, if he would just stick with the cast iron manifolds and go to duals he would be fine. But people are after a certain look I guess...
fordguy
I went with stock manifolds and 2 in 2 out down passenger side. Easy stuff.
gnsteam
Lincoln NE
Hi Doug,
I have the James Duff Dominator long tube headers installed. Check out the pictures in my build thread, page 17, post 328 - 329 and page 18, post 349. The passenger side is close in many areas but fit. I did have to add a spacer under the transfer case to raise up the rear of the engine more. To get more clearance at the frame and header.
Build thread listed below, in the signature box.
pcf_mark
I have Heddman on my 5.0/4R70W and I had to alter the flange on passenger side to get them to fit. I think I cut it off, rotated it 30 degrees and re-welded it. Everything else was fine.
tasker
all knowing of nothing
NH
had a hell of a time on my 351 and 4r70w with long tubes. Hit a bunch and way too tight to work on anything. Swapped them out with Duff shorties and all was right with the world afterward
904Bronco
904Bronco
San Martin, CA
Appreciate all the header experiences being shared... I think I have overwhelmed the Owner with all the possibilities/suggestions from the real world feedback :rolleyes:.
