heading to the dyno! UPDATED
mavereq
fired the 408 this morning. everything seems to be in order. we'll be making some dyno pulls shortly and i'll post up video/pics and hopefully a dyno sheet with some strong numbers.
mavereq
mavereq
493 tq @ 3000 rpm
429 hp @ 5500 rpm
wow.... i might have went a bit overboard on this engine. we'll see how a hp d44 handles 35's for sure.
i'll post up some video once i get it off the camera
Doyle
Looking forward to hearing it run. Care to share the specs, I've been researching stroker opitions.
Explorer
Raphine, Virginia
Impressive! Yea, better plan on beefing up the rest of that drivetrain. Don't believe a stock tranny will take that, or the rest of it.
mavereq
mavereq
well, the np435 has a fresh rebuild and new clutch. the d20 has a fresh rebuild but still needs the upgraded output shaft.
ok, i'm going to stop watching the video and go out and get some work done on the bronco so i can drive the thing someday.
Doyle
Good job on the engine, sounds sweet. Got the 35 spine axles ordered yet?
mavereq
mavereq
no, i'm going to be stubborn and snap some 31's first. after that i'll start shopping for 1 tons.
4x4x289
Excellent! I built almost that same motor but I haven't pulled it yet. I hope I can live up to those numbers. I went with a Ford 5.0 Xtreme Energy EFI XE266HR cam and a Holley Commander 950 TBI. I have the same compression, heads, and intake. For Fathers Day I asked for two tech assisted dyno runs at a local speed shop. Maybe I'll get them this year. I NEED the runs to correctly tune my Commander.
broncnaz
Sounds good probably knock off about 20% by the time it gets to the rear wheels so still 400 ft lbs is sweet.
mavereq
mavereq
how do you like the tbi? i'd like to swap to fi eventually but haven't heard too much about the tbi setups.
mavereq
mavereq
only 20%? i figured the drivetrain would eat up more than that. i know there's a shop in town with a chassis dyno. they'll probably love trying to strap down a bronco.
av8rds
MAhole!
2300 mi East of Moab
My personal results as seen here:
So over all on the chassis dyno:
Max HP = 232@4239rpm/69.6mph
Max TQ = 291.4@4051/61.5mph
down from the engine dyno of:
Max HP = 381.7@4300rpm
Max TQ = 504.8@2900rpm
This is with the 398, 4L60e, Atlas 4sp, 4.88's and 36in Iroks.
