Headlight Dimmer Switch???
Bonco4Broncos
Rockingham, NC
I replaced the old corroded Dimmer switch on my 73 and discovered I still have problems. The headlights burn fine for 3 or 4 minutes and then go off, after about 15 or 20 seconds they come back on. It does it while on Lo or hi beam. I have had this happen on older cars before but never on Lo Beam and replaced the dimmer and it was fixed. Wondering if I got a bad import switch from Advance or of there is somewhere else I need to be looking. Any ideas will be appreciated.
NicksTrix
time to replace the headlight switch. sounds like the internal breaker is soft
Steve83
Before that, try this easy check: unplug the stomp switch so the headlights go off. Then listen for the CB to click. If it still does at the same interval, then it's a short in something ELSE that runs off the headlight CB. It could be a factory load (like the horn or parking lights) or something that has been spliced into one of those circuits (like a radio, cigar socket, etc.).
Ohio Bronco 21
Cleveland
great test. Probably is the headlight switch
Bonco4Broncos
Bonco4Broncos
Rockingham, NC
I picked up a hd light switch today but spent my time putting a new Ignition switch on my Ford 8N and had to rewire part of it due to deteriorated insulation on some of the wires. Garden season is coming up and I have to get it ready to farm. Maybe I'll get a chance to lay in the floor board of the bronc tomorrow.
70_Steve
Old Guy
FWIW I had the same problem. That is, the headlights would cut off intermittently. Classic symptom of a defective thermal reset circuit breaker internal to the headlight switch. Bought and installed a new switch, and still had a problem. Bad new switch? I installed a headlight relay harness (built it myself for about $15) and not only resolved the intermittent headlight problem but got brighter headlights to boot.
laserfish
Had the same problem (don't most of us). Replaced with the Tom's headlight kit. Included the relay harness with the new bulbs. Wow, what a difference, definitely worth the money. Either install a relay harness or an entire new kit and you will take a load off of the switch and get the brighter lights as well.
Scoop
Bronco Old Fart
Cuchara, CO
Yup, new headlight switch plus the relay harness equals greatly improved headlights!!
Bonco4Broncos
Bonco4Broncos
Rockingham, NC
I ordered a 5 pack of SPDT 12 volt relays off of the Bay and will build a harness for the Hd Lights when they arrive. Thanks for all the input on this subject. I have also bought a new light switch.
YNOTBOB2007
Don't forget to clean the headlight grounds. I had a similar problem and all it needed was a better ground. Best of all it's free!
