Headliner install
Smedley
Snohomish
Install on the headliner today. After adding the Kilmat, I decided to add some heat insulation. I added some 1/2" closed cell foam insulation on top of the Kilmat before I installed the headliner. The insulation was $8 for a an 4'x8' sheet at Home Depot. I bought 2 but only used one for the top. I used some 3M adhesive spray glue to install the insulation. I bought the headliner from Toms. Definitely a 2 man job, but I chose to do it myself. It was like a monkey f#$king a football, but I got it done. Not a perfect fit, but it is done. I still need to tidy up the wiper cover install. I am missing the pside bracket.
Justafordguy
Looks great, I did the same for insulation on mine. It made a huge difference.
Smedley
Smedley
Snohomish
Thanks. There was a post on here somewhere about a similar product. When I saw it at Home Depot for $8 a sheet, I figured I'd give it a shot.
jwats73bronco
So what was the material on the floorboard and wheel wells. Kilmat? Install looks great. I like the additional insulation on top beneath headliner. I want to insulate my 1973 and make A/C more effective in south MS heat. Sound deadening would be appreciated also. I want a beach cruiser, not a rock crawler. Live in Gulfport, MS.
Smedley
Smedley
Snohomish
Yes it is Kilmat.
chuckyb
It’s great to come across this thread. The pictures look great. I bought that exact same sheet stuff from HD and its sat in the garage for months while I’ve pondered whether the stock replacement headliner will fit under it correctly. Clearly it will not be an issue. Thanks for taking the time to post it all up.
Smedley
Smedley
Snohomish
Good job. I will be doing this soon. Probably alone, glad to know it’s possible.
The headliner comes rolled and it is pretty stiff cardboard. A second set of hands would be a good idea. If I remember correctly, installing from the rear forward, for the back section, worked better for me.
Will
Bronco Maniac
Looks nice. I did basically the same by myself with the top on and a full cage. The top is solid as a rock.
