Headrest bracket
reamer
Do all Bronco seats have the headrest bracket already installed in them?
56f100bbw
Tucson / lakeside AZ
I think it’s 1968 and newer Have a provision 4 bolt plate ready to go in the upper seat back For like a 69 Mustang headrest mounts perfect
56f100bbw
1977 seat all the ford Headrest in the 70s mounted the same station wagon or car or mustang
reamer
reamer
is it possible to install them without un-doing the upholstery? if yes where do you slice the top for install? is the Mustang Foxbody the same rests? hanks
56f100bbw
You would have to take the upholstery off at the top to bolt in the bracket ,fox body mustang I think I have are different headrest. I just bought a pair of 69 mustang headrest for $70 on eBay two days ago.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
All I did was remove the back. It is tight and requires patience to access the two bolts. Once the mount is in place it is easy to feel for the slot that the head rest fits into. Then it is just a matter of very carefully cutting a slit.
