Heater Core Change
YellowBronc
Bronco God
Well, I had to change my heater core because of a leak. I know how difficult it is to hook up or remove the hoses to the the outlets. I've bent them before trying to give it a better angle but never with great success. While waiting for the heater box seal kit to arrive, I started thinking of a way to upturn the outlets. This is what I came up with..........
I cut the heater core tubes about 2" from the end. I then bought some 1/2" X 45 degree elbows from Lowes and soldered them on the tubes with the 2" ends soldered to them. This made a 45 degree upturn so it isn't so hard to connect the hoses anymore. It really wasn't to hard to do since I had taken out the heater box to replace the heater core anyway.
Thought I would share a simple mod for everyone.
JWMcCrary
But now you no longer have a factory EB....;D
Good idea Don..Thanks for the tip.
ransil
The after market replacement heater cores are longer than the stock units.
I also angled mine a bit, does require opening up the firewall and heater case holes.
tip... reconnect the cables and wires before installing the heater box.
battery was low on the camera.
70 sport WA
I had to trim one about an inch off the pipe because of the same issue, and it hasn't affected the flow or created a leak. Just used a $5 pipe cutter from the hardware store and did it carefully. If the clamp is secure enough and there's enough rubber over the pipe you'll be fine. Here' a picture -- the hose fits fine, now.
Dan
YellowBronc
YellowBronc
Bronco God
Hey!!! Great minds think alike!!! I knew someone should have come up with this idea before me. I didn't cut the holes any bigger on the firewall or box? It rubbed a little but went together nicely. Might be 'cause mine isn't as long after the 45 degree bend?????
You are right about hooking everything up before mounting the box. I instinctivly did mine that way. It was still difficult but I can't imagine how hard it would be after the box was mounted.
BronCowie
Old Timer
Vancouver, WA
Where was this post when I needed it 10 years ago? :p
Oh well, maybe I'll have the opportunity to do this 10 years from now. ;D
ransil
I didn't have a digital camera 10 years ago and CB.com didn't exist.
That is about the time frame when I did my other Bronco, it was necessary on that one cause it had some front end damage and the wheel well was pushed back a bit.
