Heater upgrade
66broncoCT
Torrington, CT
Hello,
Since I’ve been driving my bronco a lot more I’ve decided it’s finally time to do the Chevy heater motor/cage upgrade. I’ve been referencing what I think is the original thread (https://classicbroncos.com/forums/threads/heater-motor-upgrade.54371/) however I hit a snag. The blower wheel mentioned cross references to both the Chevy k10 but also to our broncos. The non-ac wheel is 5-1/4” just like our broncos. The thread is pretty old now, did the suppliers condense it into one? Or am I supposed to get the ac-style wheel which is 5-3/4”? I don’t understand why people talk about having to make the opening in the stock heater box bigger if it’s the same blower wheel.
billh1289
Jackson, NJ
Hello,
I don’t have the part #’s handy but there are some listed in this link:
https://classicbroncos.com/forums/threads/heater-upgrade.113178/page-2
I think I got a fan and cage for a late 70’s Chevy truck. Cage was definitely bigger than stock and required trimming the box. Worth changing the heater core and resealing the box whike you’re in there if it hasn’t been done.
66broncoCT
66broncoCT
Torrington, CT
Weird. The numbers listed (35602) show fitting our bronco as well as the Chevy. I have a motor off a 92 vintage f150 I tried but I couldn’t get my cage off the motor without bending it so I stopped. Guess I’ll order both the motor and the cage and see how it turns out
billh1289
Jackson, NJ
Went out and pulled the box. Part # was the same you had listed.
My best heater upgrades were a hot thermostat for the engine. 192° works so much better.
Some door seals that don't just blow cold air in.
Carpet/headliner because steel carries heat right through it like it isn't even there.
Never did the blower upgrade. This was from my days growing up in the midwest, before I moved to AZ.
66broncoCT
66broncoCT
Torrington, CT
Mystery solved. I went out and pulled my motor quick and the stock cage is only about 4” diameter and the opening is like 5-1/8 so would need slight trimming for a 5-1/4” cage. I guess so many of us upgrade to the 35602 they just called it a direct replacement in the parts interchange catalogs😂. And @Broncobowsher I’m running the stock EFI temp thermostat. Probably 192 or 195°. I only have roadster inserts and the fabric doors so I know it’ll never be sauna hot but I’d like just a bit more and figured for $40 or so I’d try the upgrade
mrdrnac
It is definitely worth it! I just have thin skinned aluminum doors and top, but the improved blower will heat me up big time now in the Winter.
sprdv1
REBEL
it's still cold here lol. Got to still do this upgrade myself, change out heater core etc if I ever wanna go winter wheeling and stay semi warm
sprdv1
REBEL
Absolutely.. comfort is big key item in having fun out there on the road or trails
pcf_mark
The funniest thing about this upgrade is when I first turned the fan on high 40+ years of accumulated dust blew out of the floor vents because the velocity was so much higher!
Check your ground and power leads are healthy too.
66broncoCT
66broncoCT
Torrington, CT
It’s supposed to rain tomorrow so I plan on installing it then. Even better I talked to my buddy who has a fleet of Chevy squarebody parts trucks and he said for the low price of beer I can come up and pull one so I saved about $30 (y)
bigmuddy
Marthasville Missouri
My best heater upgrade was when I had a 66 roadster, soft doors and top. Added what was called the Mojave heater at the time and it would flat melt the snow off the soft top and windows with a little preheat. I ran the defrost off the bronco heater and then dedicated the mojave heater to heating the cab. Only thing I didn't like was the size of the unit and the lack of placement opportunities. Ended up under the dash on the tranny tunnel.
