Agree, cut and turn would be best, drop brackets would be easiest.
That being said, I just bent my radius arms (for more tire clearance in my case), and it went much easier than I expected. I made one bend just in front of the shock mount, and one bend about 18" back. For what you're doing, I'd think that bending them as far forward as possible would be desirable, but maybe not possible.
The arms are much weaker than I expected them to be. They're only designed to be strong in one direction (forward to rear), so if you bend them more than a few degrees, you risk creating a stress riser where forces will concentrate. Probably not a problem for most street driving, but if you go wheeling, it could create a failure point. In my case, I gussetted and boxed the bends to add some strength back in. Still, I haven't decided how much confidence I have in them yet and I may swap to something stronger down the road.
