Ed74
Hi everyone,
I desperately need some advice. I have been in the process of removing my 30 year old valve cover gaskets for the past 2 hours and have had minimal progress. There must be an easier way to remove the old gaskets. is there a good solvent I can use? Also, what is the best way to prevent the old gasket material from falling into the heads? I covered the heads with oil rags, but they are not too effective. I have cleaned most of the debris out, however there is still small traces left. Will this harm my engine?
Thank you,
Ed
Thank you,
Ed
