4lowdig
Newbie
- Feb 12, 2010
- 38
I've got a 69 351w in my 69 bronco. The radiator hoses were opposite and looked bad. I'm trying to correct this. I put a 69 bronco 302 water pump on to get the hoses to match up with the radiator. I have a double water pump pulley. I drilled out a 302 3 bolt crank pulley to 4 bolt to work on the 351 balancer. The 351w crank pulley was too big and was hitting the water pump pulley. Now the problem, the crank pulley sticks out and does not even come close to the water pump pulley???? Is there a different water pump which has a longer nose? A different balancer? Help Please!
