Help a real beginner?
gladrich
I recently bought a 1973 Bronco Ranger. I have never done any type of bodywork before. The previous-previous owner sanded the body down and primed it. It was left in this condition for a couple of years I think. Now there are allot of places on the body where rust has started coming through the primer. (see pics). I am thinking that I should just sand these spots down with some 800 grit? sandpaper and re-prime. It will probably be a few months before I get it painted. This will probably be the first of many stupid questions as my 15 year old son and I work on getting this "Cream Puff" the way we want it.
Help and advice is appreciated.
daddyg
Bronco Parts Collector
Toney,AL
Welcome to the board. That is a sweet looking Bronco. I am not a body expert by any means, but I would sand down the rusted areas and re-prime it.
BoltBuster
Sand and Prime the best you can, get paint on it as soon as you can. Primer sets up the job of painting to the exterior surface and it is made to absorb paint for the bond. The better the bond the newer the primer the better the looking a paint job and lasting durability. As you can see its not a good thing to get moisture on a primer, it draws it right to the body just as it would for bonding the paint. Minimize moisture until you paint it keep it in the garage.
PS welcome to the most addicted hobby.... ;D
KJHill
Central WA
I'd say wait to do any work until your ready for the paint, otherwise you will end updoing it twice. "Why do somthing today that you can put off till tomarrow." ;D
Tuck
Procrastination, while usually seen as a bad thing, nevertheless gives you the time to think about how you will accomplish your task faster.
Steve
Grand Junction, CO
If that's just cheap lacquer primer, which it appears to be, you should really remove it all (which is probably not what you wanted to hear.) You need to use a good etching primer on the bare metal because it will bond well to the bare metal. Lacquer primer won't. And, as you're finding out, lacquer primer is not waterproof and surface rust will eventually show through. The good news in all this is that the surface rust you're seeing is very minor and not causing much damage as long as you don't let it continue.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
If you're going to do a quick sand an re-primer for the time being, 800 grit is going to take you forever to sand away the old primer and rust. 80 or 120 grit would be a better sandpaper to use.
Steve
Grand Junction, CO
80 or 120 grit???!! :eek: Only if you want to leave scratches in the metal that you'll have to fill with glazing putty or several coats of primer surfacer... 240 or 320 wet or dry is a much better choice.
crab
I also agree with the 3-400g paper and use green etching primer over the bare metal then hose some cheap single stage paint on it like some PPG. At least that will seal it up and prevent the cancer from spreading.
gladrich
gladrich
Wow this is a great board! Thanks for all the input! I have been telling myself that I really don't need to take all the old primer off but I guess it is the best thing to do. And there is still some old paint on the body that I need to get rid too. Looks like most of the body was sanded and then primed but they left the stripes at the bottom for some reason, as you can see by the picture. I think I'll hold off on the body work until I am closer to painting it as some suggested.
I have it in the garage now and that's where it will stay through the winter. Yesterday I bought a creeper, some degreeser, some wire brushes, steel wool and spent allot of time getting acquainted with the belly of the beast! Looks good and solid under there.
I am reading everything I can find on the Bronco. There is allot of info out there. I am basically trying to come up with a game plan. My thoughts to date:
1. Power breaks (Stopping this thing is a real leg workout)
2. Petronix ignitor ignition (gotta get rid of those points and Condenser)
3. Electric fule tank switch ( The current tank switch under the seat doesn't work).
4. New shocks all around
5. New seats (I like the looks of those Procar Elites) but I may end up looking around the junk yard. $$$$
6. Roll bar...not sure which one yet.
7. 3 or 3.5 inch body lift.
8. Wheels and tires...35's? Maybe 33's. Probably have to do some cut-outs.
9. Then the body work and paint
10. Then the steering wheel, bumper,soft top, winch, console, hood shocks on and on and on...
Man I am excited about this!!!
Anyway she runs great so hopefully I won't have any major drive train issues to de-rail me.
Any suggestions on my plan of attack are welcome.
Thanks again for the advice. I'm headed out to the garage!
weps
Switzerland
i don't know why people do that, but i see it all the time. primer alone will not prevent rust. to do they job right, you really do need to remove all the old primer, prep properly, prime again, and topcoat.
thegreatjustino
Stockton, CA
Uhh, no. Using a decent primer will give you no problems whatsoever with 80 or 120 grit scratches.
