Help decode engine
kaw550
The model number is c80e-6015a
I beleive the date code is 7L21
I believe it is a 68 model engine produced on November 21 of 1967. Does that sound right?
Would it be a 289 or 302?
bax
Old Member
My guess is it's a 302. 68 was the last year for the 289 but I have never seen a C8 289 date.
kaw550
kaw550
I am trying to determine if I have the right clutch.
I put in a LUK 07-120. It should fit a 68 to 77 Bronco.
I think the engine is out of a Fairlane or Torino. Would that change the clutch I need?
broncnaz
No it doesnt change the clutch. The only thing that changes the clutch is the flywheel. If you have a 164 tooth flywheel then the bronco clutch is correct. If you have a 157 tooth flywheel then the bronco clutch will not fit.
164 tooth flywheels were used in trucks and some cars with 289, 302,and 351W's. 157 tooth flywheels were used in cars usually only 289 or 302's.
kaw550
kaw550
If I remember correctly I have 164 tooth flywheel.
It looks like I have the right parts.
kaw550
kaw550
I just remembered that I had taken some pictures when I had the intake off.
I was able to see the 302 on the top of the engine.
bax
Old Member
Well, we are glad we could help.
vintage bronco
well it could be a 289 in 1968 ford offered both 289 and 302 late in the year ford ran out of 289 blocks but had plenty of cranks and rods,what did ford do? they put 289 [1M ] cranks in 289 blocks to use up 289 cranks and rods. but like others said above flywheel is what matters.
