I am completely at a loss and need help figuring out where this noise is coming from. I have a ticking or clicking sound that I am having difficulty figuring out.
I can barely hear the noise when I am sitting at and idle, but the noise can easily be heard as rpms decrease as I coast to a stop
I used a piece of hosing and listened around the engine to see if it is coming from under the valve cover, which it wasn't. I was hoping I would find an exhaust leak but did not find one. I did find a lose spark plug and it did not make a difference. The only thing that stood out was as the spark plug boot on the ignition coil. I can see an arc from the boot to the negative post on the ignition coil. Am I correct to assume that this is not normal? And could this possibly be a cause for the noise I am having? Thanks in advance for any suggestions.
