Thermostat
You should really keep the thermostat range that the car was designed for. It won't help at all to have it running 160 on a cool day. That same thermostat won't keep the engine from overheating on a hot day. I keep the 194 in mine and it pretty much stays there. If you have overheating problems, you need to fix the real problem. These things are hard to cool by nature but you need to make sure the cooling system is in good shape, the fan is the heavy duty flex model, you need a shroud, ignition timing and idle speed correct, and don't put too much anti-freeze into the coolant. It won't hurt it to get up to 220 idling on a very hot day if the cooling system is tight and the cap is good.
I've got a "77. 302, A/T, A/C, P/S, & have pulled my vintage 15' camp trailer on a 107 degree day up to Huntington Lake at 7000'. Can't say I wasn't a little worried but I'm about to make the same trip over again this year!
