mkcj
Starting the long block build but the pump cam is hitting the inside of the timing cover. What's up?
Can I trim an 1/8" off the cam with a lathe or bridgeport?
It is NOT the cam. The cam gear is what has 2 different thicknesses. Taking material off the end of the cam is only going to destroy the cam. The cam retainer will keep the cam sprocket in the same place (still rubbing the cover) while misaligning the distributor gear and all the lobes.
There is no point in modifying the wrong parts when you can simply get the correct parts and bolt them on.
No it's a 70's cover here is the cover and the cam you can see the mark on the inside of cover where the cam is hitting it. And no the pin is not coming through and hitting the washer just checked that
