...and I have no Brakes! system is fully bled, and when truck is running, the pedal goes dead to the floor. We can hear air coming from the booster rod where it goes into the booster itself (area with the rubber boot) when pumping the brakes. Could this be the vacuum leak causing this? We are at a loss. The vacuum setup everywhere else was untouched. We have the new proportioning valve installed as well.
Any help would be greatly appreciated!
Thanks in advance!
Thanks in advance!
