There are only a few ways I have seen this work w/o being a headache.
Start with 2" pipe and buy this.
https://bcbroncos.com/shop/engine/e...-flange-for-stock-manifolds-for-early-bronco/
Then slide that flange on and flare the end for a 2"
muffler bearing.
You can buy new
muffler bearings at an auto parts store or a few of the bronco houses like James Duff carry them. Sometimes the studs are a little short because the new gasket and the 3/8 flange are a little thicker than factory.
The studs can be replaced with 7/16x14 bolts if you can't find longer replacement studs.
Another option is to buy the James Duff stock exhaust manifold down pipes. They come with the correct flanges and gaskets but you might still need longer studs or bolts.
We are currently making these in 2" and 2.25" If you want a specific size plz call us.
http://www.dufftuff.com/Dual_Exhaust_Manifold_Addition_Connection_Piece_p/3091-man.htm
