Help needed on fender alignment
agboy91
Bishop, GA
All, thanks in advance. I am 2 years into a frame off rebuild of a 72 and am having fender and apron alignment issues. When I set the frame on my 2" body lifts, the passengers side fender does not mate with the fender apron and leaves about a 1.5" gap to the front and about 1/2" on the drivers side. The body sits on all body mounts squarely. I did replace both door pillars and have remounted the doors and they seem to fit fine "seams look good". I took all the measurements and they are true on both pillars. I guess the easy answer is to shim it up but I'm not confident that is the correct procedure here. I am stumped and could use your experience in figuring out my issues. I hope the pictures describe what I'm dealing with a little better. thanks again for the help.
JAFO
Beaverdam
Interesting. From the look of the fender distance from the side panel you'd think the door post is tilted back at the top, or other way at the bottom. What other body parts were replaced? The core support and all those pieces are original? Meaning anything towards the front of the door post or just the door post?
I wouldn't think you could shim that much without some metal having to buckle some place. I'm trying to picture my body without the fenders and how the core support and all mate up. When I did my door posts years back I remember that I kept installing and removing the fenders and I got the door posts and all the other front end parts installed. It was a real pita getting it all to line up. I remember I welded the support braces to the bottom of the core support and bolted that onto the frame with the body mounts in place. Then using sheet metal screws attached the aprons and worked back to the door posts, which were also held in place with sheet metal screws. Tons more sheet metal screws and vise grips, undoing and attaching until everything was in alignment. Then welding.
If you start with the front of the fender touching flat, what is hitting towards the back? Or said another way, what towards the back is keeping the fender from slipping into place?
When I install the fenders (every time), I always started with laying it on the front of the core support corner, then slipped it over the top of the door post and then it slipped into place all down the door post. I just installed the fenders for the final time just recently.
AZ73
We need pictures from the fender on apron at the windshield area. BTW. my fender had the apron mount welded incorrectly. It was about a half inch too low compared to the other side. I had to cut the spot welds out, re-position, and re-weld, but yours look ok.
A
agboy91
Bishop, GA
Ok, thanks for he feedback. so here is all the items I replaced from rust out.,
Passengers side: floor pan, door pillars, apron, wheel well, fender.
Drivers side: floor pan, door pillar, rocker panel, apron, fender
Measurements were taken as best I could prior to removal of all the above. when I put it all back, I used my measurement and others I found on this site, I clamped and screwed all pieces in place, put the doors and fenders on and all seemed to align fine. This was all done on my body dolly I made. I know, I should have done all this on the frame. Did I tell you this is my first rebuild so I'm learning on the fly here. I'm not afraid, just sometimes not very smart.
Here are a few more pictures. When I welded it all up, it was fitting really well but again that was on my body cart. when I set it on the frame, it is off mostly on the passenger side.
I too cut the spot welds out on the apron so I could move it. I put a 1/2" socket in between the 2" body lift and the mount and that raised the apron, it appears 3/4" in front passenger side allows it mate up pretty well. Is 3/4" too much to shim? what else should I check. btw, I measures the seam on the door and I am off about 1/16" on top. the seam is wider on top in the rear (pillar tilted forward" of the door so that would seem that the front would be lower not higher. Am I missing something here? Thanks for the help.
A
agboy91
Bishop, GA
also, I noticed when I line the hole up for the hood support bumper, there is a gap between the fender and the apron? any thought there?
JAFO
Beaverdam
Where the top of your door post is sitting in relation to the right side of the cowl looks correct, as I remember how mine sits. Top of the door post, the thin piece of metal at the very top, if you look standing on the passenger side of the truck, straight at the side of the cowl, that post top is almost even with the front of the cowl edge. Hard to explain. look at AZ73's #3 pic. I think that is the top of his fender at the top of the door post. See where it is in relation to the cowl. Yours like that?
Maybe your fender does have an issue.
JAFO
Beaverdam
I think a gap there is normal. I'd need to look at mine tonight, but I don't think it is not tight there. Mine lines up perfect and can take measurements and pics tonight. I think I had a slight gap, maybe not that big though.
Thing is, you will be bolting the front grill to the core support. And the fenders bolt to the grill up front, not the core support. So when you go to line up the hood, you might need to shift the grill left or right slightly. So leave all the bolts loose until the hood is in place and you can shift everything to make it all line up.
JAFO
Beaverdam
The shimming you are planning, isn't that going to make the core support crooked? Then the grill will be crooked, right? You need the core support even across the frame. You need to assess what is going on here and try to fix the body IMO. It might be a little work but worth it in the long run.
There are measurements you need to verify regarding the slope of the apron as it runs from the rear to the front. I had those written down someplace. I remember writing them on the core support in marker pen as I was working through getting the aprons and core support in proper location, in relation to the cowl and door posts.
My truck was rusted so bad the front door posts were not supporting correctly anymore and I ended up hanging the body from an I-beam in my walkout basement garage. I had I-beam hangers and threaded rod attached to some brackets I fabbed and bolted to the hood hinge locations. I then would screw the threaded rod up or down to shift the body position as I lined up the door posts, cowl, aprons, etc. Basic nightmare. I replaced the floor and then had to work with measurements from the floor up and out to the core support, etc. Took me weeks to get it all lined up. But I worked from the actual frame, not a dolly.
AZ73
I'd need to see how the PS fender is sitting on the apron closer to the windshield. Need to see how the fender to post bolt hole lines up (see my picture #3 above). Also, I had to shim my door hinges to get it to line up. I can pop the fender off tomorrow and shoot some reference pix for you.
http://classicbroncos.com/forums/showpost.php?p=2284396&postcount=67
http://classicbroncos.com/forums/showpost.php?p=2286267&postcount=68
http://classicbroncos.com/forums/showpost.php?p=2303666&postcount=71
http://classicbroncos.com/forums/showpost.php?p=2305266&postcount=72
spddmn073
Where are you body mount bushings? Those body lift pucks sit on top of the bushings on mine, that would add another 3/4 height to the core support. Do you have bushing on other body mount locations?
A
agboy91
Bishop, GA
Fender alignment
Ok, sorry for the delay, work is getting in the way of my progress. I have pretty much got the fender alignment figured out on the passenger side. I believe the issue was some bondo buildup on the front edge of the rock skid panel that contacted the lower rear of the fender causing the fender to push up. I also had a pretty significant lean so I leveled the frame and those two issues helped get me to within an 1/8" so I feel pretty good about that now.
I have the tub just sitting on the 2" lift pucks at the moment but intent to add the body mount bushings as I need the additional height to clearance the PS res and the coils.
Here is my latest issue with the alignment of the fender and apron on the drivers side. As you can see in the pictures, the apron mounting holes and the fender mounting holes are off about 3/4". The fender in order to align with the hood in inboard about 3/4". The hood closes and the lines look good when I align the hood and fender however the bolt holes are off. In my thinking, I can either add some metal to the apron and make new holes or possible bend the top of the apron in a little to get the holes to align.
I'm asking the experts on here how I could address this issue? What's the proper fix here?
Thanks for all the help thus far.
A
agboy91
Bishop, GA
I,m struggling to batch load the photos so here are a few more.
rydog1130
Try this, go get your hood and front grill. Make sure your grill still has the hood latch components. Mount your hood back on and prop it up or tie it up so that you can mount your grill to your core support with the three bolts necessary. Once you do this try closing and latching your hood... if it doesn't work chances are your aprons are too long and your front end is not square.... take a look at my build thread towards the bottom of the page http://classicbroncos.com/forums/showthread.php?t=249119&page=4 hope this helps!
rydog1130
One other thing, when I replaced my front aprons/inner fenders I used a couple of bolts to secure my fenders to make sure the holes lined up right. Im just guessing but your drivers side apron might be 3/4" too long. You may need to trim it back where it mates with kick panel. I know I had to do some minor trimming on my aprons to get them fit right
