tbratz
- May 29, 2006
- 140
Time to ask for some guidance. I replaced a leaking rear disc caliper and rear brake hose, and adjusted both rear calipers (parking brake), and now I have no fluid going to the front or rear. It is a hydroboost brake system, and after changing rear brake parts, I got in, and the pedal goes right to the floor. I tried it with the engine running and off. I pumped the brakes and worked on them for hours, checking for fluid and nothing at both rear calipers. I even reset the shuttle valve in the proportioning valve, and still no fluid. I broke the line free at the proportioning valve, and no fluid came from the valve. I pulled both lines from the MC to the proportioning valve, and there is no fluid leaking from the MC lines either. Even when I pump the brakes, I don't get any fluid from the MC. I checked the pedal linkage to the hydroboost, just in case, and it seems to be functioning properly. Before putting on the new caliper and rear brake hose, the Bronco ran fine, and the brakes worked perfectly. What am I missing? Any ideas would be appreciated. I have messed with it for two days, and I am stumped.
