Help Setting Initial Timing MSD-6 System & Holley TA 670
Jeff10
Indianapolis
Hi Everyone,
I have been tweaking the carburetor and ignition system on the '70 Bronco we bought last winter.
The motor is running pretty fast at idle, which may, or may not have something to do with timing.
I'm hoping that someone may have a similar setup and can possibly tell me how to get the timing pretty close.
Specifics:
- Motor: 347 Stroker
- Cam: Mild (RV?) Crower
- Carburetor: Holley Truck Avenger 670
- Distributor: MSD Pro Billet
- Ignition Box: MSD Off-Road
I have done some Googling here, and on MSD's site; but, I can't find what I'm looking for.
My primary question concerns setting the intial timing. There is no vacuum advance hooked up on the distributor, so my thinking is that the MSD-6 must control the advance electronically. (Sorry if that is a bad assumption.) Do I need to do anything (such as disconnect the MSD-6) to make sure the initial timing is correct?
I am working on setting the timing and tuning the carburetor, so I'm not sure which I should start tweaking first. (I have rejetted the carburetor to stock and I have reset the idle screws as instructed by Holley as a good starting point.)
Thanks in advance for any help or suggestions.
Jeff
mdw_75bronco
Pottsboro, TX
i had the exact same set up as you and the same problem. I finally had to swap my distributor with one that had a vacuum advance.........much better results. slowed the idle down. I was able to sell my 6AL and pro-billet distributor on EBAY. I bought the pro-billet distributor w/vacuum advance and didn't use the 6AL ignition control. The new distributor had it built in. I think it was around $400.00. I didn't have to do anything to my holley carb.
NC-Fordguy
Bethel/Greenville NC
Got your pm.......
Sounds like you have a centrifical advance distributer...I have one myself but have had for many years so it may not be the same model. Mine has run without incident since I installed it.
There is no vacume advance for this distributor. Make sure the vacume advance port on the carb is plugged.
Setting these distributors up so they advance correctly is done by the particular set of springs inside the caps. I ended up using the gray ones.
I assume you have the spring kit for your distributor?
Set timing as you would any ordinary distributer...think mine is 10 degrees btdc
nvrstuk
PNW
So set your timing at appr 8deg BTDC with the idle at 750 or so. Keep adjusting one while adjusting the other till both are set. You don't disconnect anything on your MSD to set the timing.
Then move on towards setting the idle mixture screws on the carb.
broncnaz
I'll piggy back. Back the idle down with the idle speed screw, set initial timing between 8-12 degrees and adjust the idle mixture screws to attain the idle you want. Setting the idle mixture is best done with a fully warmed up engine.
if you cant get the idle speed to come down then you may have a vacuum leak somewhere.
Jeff10
Jeff10
Indianapolis
Hey Everyone,
Thanks for the input. I'll take a closer look for a vacuum leak before doing anything else.
It seems odd that there is a vacuum bowl on the side of the distributor; but, I don't know a lot of history.
As far as the springs go, I don't believe I received a spring kit from the PO. Might be something I'll need to purchase when it comes time to fine tune things.
(Thanks for the info on not needing to disconnect anything from the Offroad box.)
I will keep you posted.
Jeff
Jeff10
Jeff10
Indianapolis
Hey,
Quick update.
After talking with Holley, and getting some good advice here, I focused on the choke. The choke was connected electrically; but, the connection was sloppy. I tightened up the female connector for the ground mounted on the choke body. Restarted the engine, and it was able to idle with no problem this time, and although it still may be a little rich, it's nothing like it was this past weekend.
This coming weekend I will set the timing with the lower idle RPM and then tweak the fuel settings using a vacuum gauge.
(I also have a message into MSD requesting advice on what I should do regarding the vacuum advance on the distributor. I'll report back when I hear from them.)
Thanks for all the help.
Jeff
Jeff10
Jeff10
Indianapolis
Hi,
No call backs from MSD....
Is anyone else running a MSD distributor which has the vacuum chamber without connecting it to a source for vacuum advance?
Jeff
broncnaz
Do you have vaccum advance? vaccum advance is usally hooked up to ported vacuum on a holley thats the port behind the primary fuel bowl fuel level sight plug.
Vacuum advance helps with part throttle driveability as many times the engine can use more timing than the mechanical advance gives at that engine speed. So basically the vacuum advance can fill the gaps where the mechanical may be to slow.
I've run both vacuum and no vacuum dizzys only saw minor differances in perfromance in my setup but the vacuum probably edges the non vacuum out in lower RPM's
Jeff10
Jeff10
Indianapolis
Hey broncnaz,
Sorry if I am making this confusing.
I bought this Bronco in December of last year. It has the MSD Off-Road electronics package, rev limiter, and a MSD distributor.
The distributor has the vacuum advance hardware on it.
But
The previous owner did not have the distributor vacuum chamber hooked up (to anything). On the '71 I have the ported vacuum connection on the Edlebrock Performer. (That is a change from when it arrived... it was hooked up to full manifold vacuum by its previous owner.)
Where I am confused is how the MSD Off-Road electronics plays with the distributor timing...
Maybe I'll just hook the distibutor up to the ported vacuum connection on the Holley and see how it does.
Thanks for the reply.
Jeff
broncnaz
Initial timing should be set with the vacuum advance unhooked(it really shouldnt make a differance if using ported vaccum but just to be sure you unhook it) then you hook up the vacuum advance idle speed shouldnt change when its hooked up. If it does then its either not ported vacuum or your throttle plates are open to wide and its getting a vacuum signal.
The MSD offroad box like most of there other box really only produces multipule sparks. basically it sends a series of high voltage singals to the coil each time a cylinder fires. it really doesnt change or control timing. So the MSD electronic really dont play a part in actual timing.
Jeff10
Jeff10
Indianapolis
bronconaz,
Thanks for the explanations.
I was pretty clear on the vacuum advance... just can't figure out why it wasn't connected.
I have read about the multiple sparks on the MSD box, too.... I just wasn't sure if there was something I was missing.
Take Care
Jeff
Jeff10
Jeff10
Indianapolis
Hey Everyone,
I've been working on this matter a little bit at a time.
Just so it doesn't get lost, the (minor) problems that I have right now are dieseling on occasion when turning the motor off, and an idle speed that sometimes fluctuates slightly. The idle is set at about 800 RPM. With the motor idling, and not horsing around with the throttle or anything else on the motor, the idle speed will climb to 1,000, and in some instances to 1,200 RPM. It's not bad really, just not where I'd like it to stay steady.
Here is what I have done so far:
1. Replaced the throttle return springs.
2. Re-jetted the carburetor to the settings specified by Holley.
3. Replaced the throttle cable (with a Lokar) to get better throttle response.
4. Adjusted the idle mixture 1-1/2 turns out from fully seated per Holley's recommendation.
5. Verify that the vacuum advance port on the front of the Holley is capped.
6. Set the timing to 10 degrees BTDC.
7. Adjust idle as close to 800 RPM as possible.
8. Check and reset timing.
9. Adjust the idle mixture using a vacuum gauge, moving from one side to the other until the highest vacuum is achieved.
10. Reset timing.
11. Adjust idle.
12. Readjust the fuel mixture.
13. Loosen the carburetor from the intake manifold as recommended by Holley. Square up the carburetor on the manifold. Retorque all nuts to 60 in-lbs in a pattern to prevent warping.
14. Adjust the accelerator pump linkage to 0.015".
15. Continue tweaking the timing, fuel mixture and idle.
16. Just for kicks, I sprayed carb cleaner around the base of the carburetor with not noticable change in RPM.
I'm also not sure about the fuel that was in the Bronco when I bought it. The tank is getting low so I bought 2 gallons of 93 octane pump gas today. (That's the biggest can I had available.) I have been running this gas during the last 1/2 hour of checking and adjustment.
I think it is pretty close... I'm just not happy with the slightly inconsistent idle and the dieseling.
Maybe I am just thinking I can make it too good.
I would like to convert this Bronco to propane later. If I end up feeling like a new carburetor is my best choice, I might be making the move to propane sooner, rather than later.
Anything I'm missing? (I really can't tell you how it does on the street as I haven't had it out of the garage in several months.)
Thanks for your help.
Jeff
broncnaz
sounds like a vacuum leak have you retorqued the intake manifold bolts? Doubt you need a new carb. Bad gas will also cause the issue. might put in some 86/87 octane the lower the octane number the better it will ignite. putting in 93 octane is not going to make much differance as the octane of old gas tends to be higher thats why it doesnt burn as well. So its better to mix in the low octane gas with old gas.
nvrstuk
PNW
So I reread all your posts... get RID of the old gas! Do it, ethanol mixed gas starts breaking down in 30 days-seriously, it does.
Drain the old crap out, put in at least 8-10 gallons of regular and try it. You might still need to rebuild/clean the carb-by dipping it, not by the .02 method of spraying it with cleaner.
My hi-performance 2 stroke engines won't even start (seriously) on ethanol mixed gas when it's over 6 months old.
Jeff10
Jeff10
Indianapolis
Hi Guys,
Thanks for the input. The tank is almost empty so emptying it shouldn't be too tough.
The carb really looks good. (I know looks can be a little deceiving.) When I pulled it to re-jet it, there was no build-up inside that I could see. I'll take another look.
Jeff
