Have been working on installing the front portion of my Wild Horses 2 1/2 Lift Kit with 14 piece bushings and 3 way adjustable tie rod and drag link. After spending a lot of time getting the radius arms into shape my son and I started the install and although I had read a lot about C Bushing troubles ours went in quickly since we followed the directions provided by Heuss33.
Problem came up when I got to the part of reinstalling the tie rod and drag link. I mocked up all of the measurements based on the old unit and really thought that this would be a drop in replacement. Tie Rod went in without a hitch and then I installed the drag link and realized it was not going to fit. (1st Picture)
I have some pictures below to show that when the tie rod in bolted up and I install the drag link into the Pitman Arm that I am still several inches away from being able to insert the drag link into the tie rod. I tried jacking the differential up as high as it would go before it started linting the frame off of the jack stands and still could not get there.
Other pictures below show that I took off the original drag link and installed it and it fit. There is also a picture of my Pitman Arm which I believe is a drop (Picture 3). You can see that even with the old drag link, the shaft is pinned all the way to the right which makes me think I need more drop on the pitman arm.
I assume someone will ask so I will post it now, I am going from a 2.5 or so lift to a new 2.5 inch lift. As a matter of fact the old springs are maybe 1/2 - 1 inch taller.
I assume that I am just hooking something up wrong or missing something obvious. It has been a long weekend and a bit hot so I called it a day and hope that you guys can give me some things to try tomorrow after work.
Thanks,
Jim
Thanks,
Jim
