- Jun 13, 2012
- 821
After some good help and tips from members on one of my previous posts its now time to move on to the next step. I tapped and plugged the EGR hole on the lower intake and now wondering what i have to do to the upper intake to complete the EGR delete.
its been quit sometime since i took everything apart and my memory is serving short of what is what lol.
can someone tell me what all the hoses and tubes are and whet needs to be plugged and or modified for the EGR delete?
also i have been on the fence about deleting the evap system till this point. i spoke with Gary EFI guy today and he is ready to start working on my engine harness therefore a decision needs to be made real quick. he mentioned prepping the harness with the evap wires tied off if i choose to go evap or not, or if i dont then he wont run the wires at all and no ECU programming required either way.
should i keep or delete the evap? if i delete what do i need to modify on the upper plenum to makes things work properly?
thank you in advance
JP
JP
