YellowBronc
Bronco God
- Jan 6, 2002
- 1,830
Alright, I've put up with this long enough. The problem of the shifter has gotten so bad that sometimes I have to work with it to get it to go all the way to park. I've done the adjusting thing and really have only delayed the inevitable.
Below are the pics of the adjuster bolt (don't know what else to call it) that attach's the rod from the column down to the linkage on the transmission. The linkage on the transmission has only started to become out of round and isn't to bad, yet. The linkage on the transmission was replaced at rebuild 3 years ago. However, I couldn't find the adjusting bolt anywhere so I reused it. As you can see, it is worn really bad.
Does anyone know where I can get a replacement? I've hit salvage yards and tranny shops without any luck. Even if someone has one laying around that is in better shape? I'm getting desperate here!![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
