On my half cab I have it on top off the rear fender. Fits between the tail gate and the bulk head. When I get duffys new tire mount I'll hook it up there. ;D
I have had mine bungeed to the kicker bar on the cage. When I built the latest bumper, I mounted it upside down in a piece of 2x4 box section that holds the tire. A bolt through one of the holes secures the jack. The jack base makes a nice handle to grab the spare tire and pull it away from the truck.
I mounted mine to the inside of the custom tire carrier I built. The jack fits perfectly in the tail gate (the space that indents) you can see pictures at www.kramerproducts.net under tire carrier.
Mine is mounted ont he roll cage on the piece that angles to the back from the center loop.
You can kinda of see it here:
I used exhaust cclapms to go around the roll bar and then for one nut on each i used a thing that has is like a long (2 inch) nut with threads on both sides. Then a bolt through jack into that thing.
I need to modify Duffs on to my bumber. mine is made out of C channel stock. If the mod wont work I'm getting the whole kit. i saw a few down at sand lake. They take it real well.
Ryan
