hi lift jacks
buckstone
los angeles, ca
looking to buy a hi-lift jack. any suggestions? should i get a 60" - or is 48" sufficient? also, whats the diff between all cast and cast/steel? i'd like to get something that is good, but not too expensive. i'll be doing some off -road occasionally. thanks.
rustbucket
Either 48" or 60" would be fine. If you plan to use it as a come-along, the 60" would allow you to pull farther without changing positions. The all cast version is stronger.
broncnaz
go with the cast version in the 48" lenght it fits inside across the rear bed of a bronco perfectly I'm not sure how you would carry a 60" one in an EB
