If you're using your MSD 6 box in addition to a stock Duraspark box, then yes, you just replace the Duraspark box with this one.
If you're only running the MSD box, then I think they make a Timing Control box by itself (no integrated ignition module) that would hook up to your 6AL.
Are you familiar with how the PCV system works?
You should have a PCV valve plumbed between one valve cover and the carburetor's large vacuum fitting. The other valve cover would have a filtered-air inlet. Either with it's own filtered cap, or a hose plumbed into the air-filter housing to get clean air into the engine.
If you don't, then you could very well be running overly rich just for that reason alone. Depending on how your carb was set up originally.
Oh, and you definitely DO want a PCV system on your engine. No ifs-ands-or-butts in that regard.
If you do have an existing valve, then what I was talking about was simply replacing the existing one for a different one that allows the engine to basically suck more air.
With my 302, it was accomplished by replacing my existing one (not stock to begin with) with one from a mid-seventies 302 in a passenger car.
With your Cleveland however, which one you use would depend on what setup you currently have.
I found mine through accidental experimentation with multiple units. Very likely you could use the same models I did, but I'm only guessing.
Most Ford and GM PCV' valves fall into two sizes of hose barb, and straight or 90° ends. From there they can have a different number (usually 1 or 2) and different rated "pills" which are the actual slugs that are inside and do the opening and closing of the port along with a spring.
I'm currently using an early '70's Corvette 350 version, for normal use, to get the 90° 3/8" hose fitting and the right vacuum signal. The Granada one had the same physical dimensions as the Corvette, but with a different pill rating.
Hope that didn't conuzzle things just before your fun trip (and you ARE going to have fun, no matter what!) but you might want to check to see just what's plumbed into your valve covers. Just for giggles.
