I can't help you with the rear bumper mounting, but if you are interested, I can take some pics of how I mounted my Hi-Lift on the Roll Bar. It looks sweet, and it'll be out of the elements. I used Muffler clamps and some misc. hardware to hold it in place.. Looks sweet, and doesn't rattle...
For the quick, easy way... Weld a couple of 5/16" bolts onto the frame horns sticking out backwards. Line them up so that they fit through the Hi-Lift main rail. Add a couple of washers and nuts. Away you go.
If you want to get really fancy (%) ), weld a peice of tubing or channel across the frame horns and then weld the bolts to them. That way you will have something to jack upon.
That is a really good idea! I need ot move one of my clamps up the rollbar a little but then I will need ot repaint where it was. If I had usd some gasket material, Iwould be good to go!
If you want to put in on the frame just buy some bolts and put them through the hole where the bumper mounted and then line up the hilift. I had to put some spaces on the bolts so that the jack would will tighten down. It worked well for me until I got a bumper.
Sweet roll bar attachement, I have put mine in 3 other locations, all having their faults. I will be changing to the one de-picted thanks admin, as they say..... a picture is worth a thousand words!
btw...... any problems with that mounting when used in conjunction with a fastop soft-top?
THere should not be but it depends. In one of the pictures I have the soft top on and there is ample clearance. I have a protofab roll bar. A Smittybilt will put the jack closer to the top. like I say shouldn't but no promises.
As you can tell, it doesn't work too bad with the bikini top on. But it would be hard as hell to get out if you had a full soft top on. I guess you'd have to unzip your windows. Thanks 66horse for the idea! I love it!
Oh yeah...I used ruberized undercoating on the exhaust clamp and bolts, worked great!
