High pinion D44 question
Banjer Picker
Have a friend looking at a full width high pinion D44.
He’s got a 3.5” suspension lift currently.
If any of you guys are running this set up have you had issues with clearance issues with the oil pan?
He will be doing some moderate rock crawling.
Justafordguy
If it's full width it should be fine. Just make sure the bump stops are setup correctly.
377
The Bluegrass State
I’ve got a 3 1/2” lift with a HP full width and no oil pan problems. Agree on the bump stops they take a little fabrication.
garberz
Bronco Influencer
Conejo Valley, Ca.
I have a narrowed HP44 with a 3” lift. Running an Explorer 5.0 with the AWD aluminum pan. The diff and the pan have plenty of clearance. My front axle is pushed forward 1 1/2”, I know that helps, full width will move the diff 3 5/16” towards the drivers side, away from the pan and transmission.
Mark
Banjer Picker
Banjer Picker
Mark
Thanks Mark. Lance is looking at Jeff’s old axles since he went to one tons. They’re already set up with all the goodies.
68ford
Full width has zero oil pan issues. Diff hits engine mount tower on frame way before the pan. My high pinion full width goes up 1.5 in closer to the frame than the original d44 and stock bumpstops.
