Holley Commander 950 TBI
Passauf
Has anybody used this unit or have an opinion either way. It seems easier than a multi port style system. Thanks for your input
Desert Thrasher
This is what I am thinking of getting for my cleveland for the Bronco. It seems like a great system. You dont have to go junkyard searching and end up with used, wore out parts. Everything is brand new. The only thing I dont like about it is that you need a laptop computer to tune it, but thats only cuz I dont have a laptop. For me it is a great way to get fuel injection for an engine that never had it before, and it could be a great way for many others too but if you have a 302/351W then you have a lot more options.
67ster
Holley has been at this EFI business for a while but their units don't seem too popular here or anywhere else for that matter. Some have reported good luck with them while others avoid them like the plague. There are others out there that can be tuned by twisting knobs for low, mid and high RPM ranges. Some have a custom chip burned just for your application , others are a collection of OEM parts and a custom harness . I don't have a clue as to what is best so I'll stick with my Motorcraft and points for now .
Bucmaster
I had the first generation Pro Jection and I could not tune it at all. Either too rich or too lean. I still have it in the box on the shelf.
westco
Klamath Falls, OR
I hope these work better than the pro injection. I have 10 friends that got rid of it and switched to the avenger carb. If it works well let us all know.
sicaz66
san diego
from what i hear only GAY people and jeeps use it! :-*(lol) so when you picking it up?? ???
P
Passauf
Why does every group have to have a turd in its ranks. Bronco God or not I think you spend to much time in the bath houses!!!!
I have the old Projection system. I was told to avoid it and get the comander 950 because it is leap years better then what I got.
So consider it a step above what I am running. I have had a few glitches. All installation related. I grounded the ECM to the body. Caused a super rich condition at night with the headlights on only. Changing a ground fixed it. The other was a wire fell off the fuel pump.
As for tuning. The only possible way to tune one is with a laptop and the data logging software. Without that, you will never be able to tune it. I tried for a year. When I started logging, I made more improvements in 1 day then I did in the past year.
The Comander 950 uses a lot more generic get anywhere GM parts then the old system.
