Holley EFI tuning
garciaj
lakewood
Hello friends
Ive installed the Holley terminator a couple years back and it needs some fine tuning which i know nothing about. Once in awhile on decel from above 2k rpm i get an exhaust back fire which drives me crazy . Im looking for someone or some shop that can go through and fine tune in the denver area .any suggestions would be greatly appreciated.
garciaj
garciaj
lakewood
Holley forum hasnt been too friendly or helpful i just keep getting linked to articles that make no sense to me . Im also sketchy about going in with my laptop and screwing something up.
hotrodtim68
Holley EFI help.
You may want to try EFISystemPro. They are located in Palm Bay Fl. Won't hurt to give them a call. Look them up on the web. Chris Meyer is a knowledgeable guy.
RODRIG3911
Tucson
Save your gcf file and you can mess with it all you want and go back after to reload your known “Good” file..... Sounds like you should adjust your Decel Fuel Cutoff. Worked for me to solve the same issue on my Holley Sniper.... Also, what’s your IAC reading?... I noticed lots of times resetting the IAC fixes lots of issues with Sniper. Probably similar with terminator.
garciaj
garciaj
lakewood
Ive never messed with the decel cut off i am familiar with saving my global file though ehich i have done. What kind of decel cutt off adjustments am i going to make increment wise.
73azbronco
did you ever have an exhaust pop before. If so check for exhaust leaks.
garciaj
garciaj
lakewood
Just since ive installed the EFI wasnt too concerned just annoyed . Checked for exaust leaks didnt find any
RODRIG3911
Tucson
Play with it. If decel is on turn it off, if it’s off turn it on and see what it does (I can’t remember which way mine was when it was popping on deceleration).... Also what’s your afr’s doing when it pops? Is it lean or rich. Pull a data log and see what it looks like when it’s happening.... these are just ideas from learning about my Sniper efi. there’s lots of good YouTube videos on tuning them.
JWMcCrary
My IAC after warmed up is down around 2, but under 10 is in spec as long as it isn't sitting on 0. Your AFR when you give it a little throttle seems like it's all over the place, wondering if maybe your 02 sensor might be iffy. Just throwing out there because I'm certainly not an EFI troubleshooter, I just pray it starts and runs.
RODRIG3911
Tucson
It's not exactly what I was picturing as far as the pop, so good job on that video... When it happens your AFR's go maxed out. I think we're on the right track looking at exhuast leaks, decel cutoff, and timing.... Also, what is your fuel delivery system? Got a good return line if it's frame mounted?
garciaj
garciaj
lakewood
Frame mounted holley that came with the kit and i used this kit for a return line that splices into the filler neck close to the tank
