Home Made Blasting Cabinet
AZ73
Had a need for a small blasting cabinet to do my A/C louvers and couldn't see spending $90 (using the 20% discount) at Harbor Freight, plus it was a large cabinet. Went on-line and got some good ideas for a home made one and incorporated them into this build, done for under $40 plus using some things laying around the house.
1 - 26 Gal Sterilite Tub - $16.95 from Home Depot
1 - 10X12 piece of glass - $2.44 from Home Depot
2 - Oatey 4KMP4 toilet flanges - $4.01 each plus $5 shipping from Zoro
1 - Pair long sleeve blasting gloves #4468 $6.49 less 20% ($5.19) from HF
Plus some caulking, double stick foam tape, screws, zip ties, and duct tape laying around the garage.
1) Lay glass sheet over inside of lid and outline
2) Remove glass and measure in 1 inch from outline. Draw new rectangle
3) Use box cutter to cut all 4 sides of inner rectangle. Remove cut piece
4) Lay glass sheet over open hole, and tape down using duct tape
5) Flip over and attach cut piece back over glass and attach one side using duct tape
6) Cut tape at edges of glass 1/2 way to form hinge. This will act as a cover to protect the glass when not in use, but flip open when in use.
7) I used the Sterilite because it's transparent so you won't need to install a light in it. I saw others on-line made out of cardboard boxes, but they needed a light inside. I picked the 26 gal because it's taller than most of their other sizes with enough room in it to work
8) Cut 2 4-5/8 holes. I used a hole cutter, run in reverse so the teeth don't grab the plastic and crack it. This basically melted a hole in the container. I cleaned up the residual melted plastic on the edges with a razor when it hardened. I also cut one hole in the front left, and one on the right side. I practiced holding items and the blaster over the tub and it's not wide enough to put both holes in the front and be comfortable. Was more comfortable to cut the holes in this fashion.
9) The tub isn't perfectly flat on the front, thus the flanges won't fit perfectly flush. I wrapped the outside diameter of the front flange pipe with a ring of double sided foam tape, then a thick bead of caulk. The flange has an outside diameter of 4.5 inches and an inside of about 4 inches. This will fill the gap between the flange and the tub. Press in and screw or bolt into place.
10) The tub isn't perfectly flat on the side, it's concaved in, thus the flanges won't fit perfectly flush. I wrapped the outside diameter of the front flange pipe with a ring of double sided foam tape in a wave pattern so when it's inserted, it will seal with the majority of the tape on the inside of the tube. Push it in, lining up the tape with the concave, and screw or bolt into place. From the inside run a small bead of caulk around the mating surface.
11) peel tape protective surface off, and stretch glove over the flange and tape, then press down onto the tape. I then added a zip tie to hold it in place. Make sure you put the correct glove over each flange.
I borrowed a 20 lb pressurized HF blasting unit from a buddy and will drill another hole to run the the line in after taking the nozzle and trigger valve off, putting them back on inside. I'll also drill another hole to attach the shop vac.
I'm going to try it like this and hope the shop vac keeps the pressure down, else I might have to run some insulation around the lid since it's not completely sealed there, and may need to add another hole with a piece of nylon stocking over it to let air in when I'm not blasting but the vac is still on. Will report back when I use it in 2 weeks. Any ideas are welcome.
AZ73
AZ73
Finished product! I'm going to use this cabinet since I'm using glass beads which can be reused up to 10 times. No sense in letting them scatter all over the yard. Just collect, screen, and re-use. If I end up needing something bigger in the future, I'll probably make one out of wood and just move the flanges and gloves over.
dave67fd
Neat idea as well but depending on your blast pressure I might be worried about blasting a hole thru the plastic at some point. Also depending on the power of your vacuum you may need some form of intake.
But for the price give it a shot.
badmuttstang
redneck grease monkey
I was thinking the same thing about blasting a hole thru the plastic and have seen people make blast cabinets out of plywood that don't last long either though and they spend alot more. So it worth a try and definitely will keep the sand from going everywhere in one shot.
dave67fd
Maybe at least lay a sheet of metal on the bottom and be diligent on pin pointing your blasting.
AZ73
AZ73
Thanks all. I'm using #200 Glass bead and the container is Polypropylene. On some blasting sites I looked at earlier they claimed the Polypropylene is soft and flexible so the beads should bounce off, or take a REALLY long time to work through. It's the same material used in Medical plastic products and Glass Bead was too soft to do much to the surface so they use other media to prepare for painting parts. If I was using Aluminum Oxide it would be a different story, but I see your point. I think putting a sheet of metal on the bottom couldn't hurt. It's going to be an interesting experiment!
