American Pride
my prop rod is shot and was thinking of putting those hood shocks but for $70+ it seems a bit high. has anyone made there own?
Ok, after a wind gust and a wonderful headache, I would like to see the pics!TOFIC said:Bought mine from the UJerk yard for 15 bucks.
Off an Nissan minivan the rear shocks
A little fitting and viola hood shocks!!
Got pictures if you want to see
TOFIC
Just got back from my wilderness adventure. (I could of lived without it!!)Hawkdoc said:Ok, after a wind gust and a wonderful headache, I would like to see the pics!
Sent the pics to you and the other gentlemen that asked tonight. (man dragging my feet these days!!)Hawkdoc said:Ok, after a wind gust and a wonderful headache, I would like to see the pics!
In my kits the fiberglass lifts are weaker and there are 2 stiffener straps to epoxy the lift mounts to the hood. The lifts for the steel hoods are stronger. If the lifts are too strong they will damage the hood, if they are too weak they will not hold the hood up or will not last long. The fender brackets I designed to set at a angle to decrease side load. Others set the lifts up to go foreword when closed. This gives a little more room to work when the hood is up. I designed my lifts to go backwards when closed. You lose a little working room when the hood is up but when the hood is down the lifts push the hood down while the others tend to push the hood up. Also if you need the extra room my lifts will un-snap to be totally out of the way. Also My lifts have a 1 yr. warranty. All of the above is included in the price. Also hood shock is a trademark of B.C. Broncos.jkskier said:OK so here's a potential curveball:
What is the difference in the vendor kits when you specify fibergalss v. stock hood? More powerful spring or different mounting and angles with the same spring? Is there a pressure rating with these shocks that you can use to say, ok, this is too much pressure to place against fiberglass for a long period of time?
TOFIC said:Also hood shock is a trademark of B.C. Broncos.
Jesus, I am guilty of poaching!! GAWD sorry Chuck i did not know!
I will cease and desist my references for this point forward as it is not my intent to do anything illegal.
TOFIC
Hi Sallyontherun said:;D Okayeeeeeee,... I'll bite,.............;
Dude,.. you sound like me during "that" time of tha' month,...... ( poor Landis,... he has high tolerance,. S.
I don't mind you using Hood Shocks as long as you are not selling hood lifts as "Hood Shocks" or discribing low Q poorly engineered/thought out stuff as "Hood Shocks" That would be as bad as calling a diet RC a dietcoke.TOFIC said:Also hood shock is a trademark of B.C. Broncos.
TOFIC
