Guys,
Can i buy replacement horn contacts that are found under the horn button (or in my stock case the half moon button)? The two contacts are on the plate under the button (on the wheel side) and have white plastic holders that are attached to the the plate by one screw each.
Also, when you pull off the steering wheel (1972) there is a small spring around the shaft holding in a plastic sleeve that centers the shaft in the column. Am i missing anything?
