Horn Repair Saga
67RT
SInce day one my horn hasn't worked, probably the only thing on this old truck that hasn't. After watching some videos and reading some threads, I started troubleshooting. I pulled the wheel and started testing wires.
1) Yellow wire at horn switch in wheel: Hot, good news.
2) Jumped the two copper spring loaded contacts (yellow wire to blue/yellow wire): no power to horn
3) Continuity from blue/yellow in wheel to blue/yellow wire at horn:infinite resistance. Ok, bad.
4) Unhooked wires coming out of column under dash and started pulling off electrical tape. I find all 8 were cut and crimped, probably when the shifter was changed to the floor. Horn wire was off (see pic). Recrimped, taped, etc.
5) Jumped two copper contacts and now have power at horn, but horn doesn't work. Ok, so horn is bad.. But..
6) Put wheel back on with horn button and depress, no voltage to horn.
So now I have a question that the other threads don't answer. My '70 has the two copper contacts, one touches the inner metal ring inner wheel and one touches outer metal ring.The two outer plastic/metal contacts on wheel that make connection to horn button (both hot) are both screwed into a round metal ring that will only contact inner ring.
What contacts the outer ring to complete the circuit.
Pardon my brain farts but I have no manual and can't get my head around this, or I am missing a part.
67RT
67RT
Pics. I think i have the right button. It seems like outer contact touches outer ring which in turn is connected to metal tab coming thru front of wheel, which touches flat part of horn button. Maybe copper is too worn down?
House
Minutia Militia
You are missing another contact and ramp on the other side. You can see the clean spot where it belongs. (Middle picture)
67RT
67RT
Hi. I removed that contact because it is broken. I should only need one to test it.
I tested continuity between inner and outer metal ring of wheel with horn depressed and get no
resistance,so the circuit is closing. Now I am pretty sure the copper contacts on the turn signal switch are worn out... bummer.
67RT
67RT
so I used a soldering product called muggy weld and soldered a little piece of copper on each contact. Now I have 12 volts at the horn. I wish I had a good oneto test it
bteutsch
Also those contacts I had to bend them up and the install the horn ring for them to make contact.
phldwsnoc1
Jarrettsville, MD
On mine the horn would work in specific spots in the wheel rotation. One of the rings, outer I think, was not flat when installed. I put a tiny washer under each of the attachment points to space the ring toward the brushes. Perfect.
67RT
67RT
This is a good tip.
Do all vendors carry the same horn?
phldwsnoc1
Jarrettsville, MD
Not sure but most repro parts I have used are rubbish. Find a modern vehicle with the sound you want and buy the horns. I have horns from a current 4Runner and they sound great. I added a relay as well. Happy to offer details as needed.
sykanr0ng
Ford Super Duty horns have been reported to work well, though the Super Duty guys often go to air horns.
67RT
67RT
Great suggestions. I am a mopar guy so I bought a beep beep horn and a bosch relay. Should i fuse the relay and if so on what branch. I have Pauls previous post on what wires go to what pins.
