Nightstick
Bronco guy
- Feb 6, 2010
- 2,929
I'm in the middle of tearing down a D20 T-Shift. Like some others I get to the step of removing the front shaft bearing and it ain't coming out. This does have the snap ring behind the bearing. The bearing will NOT move at all even after an hour of wedging, heat, and PB Blaster. I've looked at a few other threads, and they mostly talk about the J-shift. I'm stuck, so I'm hoping someone has a suggestion.
Let me make sure I'm clear on exactly what I have to do... Move the bearing foward, remove snap ring, take shaft out. Here's the problem I see. The bearing is tapered with the small end toward the outside of the case meaning the cup/race is stopping the bearing from moving ?:?
I tapped the shaft back and it moved about 1/2", but this doesn't solve the problem because I still can't get the bearing off. Does the bearing need to come all the way out to remove the snap ring, or just a little?
While I'm at it, I'm also having trouble removing the slide gear. Am I supposed to move the shift rail forward to get that out?
