How do you repair a Vent window?
Gweiner
Charlotte
Was going to replace the pivot spring assembly on my vent windows but the little stainless "L" piece that was soldered or welded on to the frame attaching the window broke. Can it be re-welded? If so, what type of weld would work on stainless? I have a Lincoln 110 Mig unit but afraid mu hav skills may damage it.
Appreciate any suggestions.
Attac
If it is the threaded pivot rod that you are talking about then it is riveted on. The best way is to remove glass and rerivit a new one in but I have fixed one with blind rivits before. Depends on how deep your glass is in the bottom track.
Chuck
G
Gweiner
Charlotte
Thanks. It's not the threaded pivot rod. It's the welded "L" hinged bracket that attaches the window frame to the outer frame. There were two small weld beads that just broke. Unfortunately my contributor status expires. Otherwise, I would post a pic.
Attac
Oh I got ya. I was at wrong pivot. You may be able to braze it. Might be a little more controllable than welding
