How easy to replace D20 with NP205???
M
Miley
Guest
Has anybody done this?
I'm looking for any input I can get.
Jim
lars
Been here awhile
NorCal flatlands
Pretty common swap. How much effort depends on which transmission you'll be installing behind your diesel. Ford used the 205 behind the NP435 transmission for years on F series pickups, so if you are planning to use that transmission anyway then it's simple- the transfer case will already be bolted to the transmission. No adapters needed.
M
Miley
Guest
I have an NV4500 with the D20 adapter on it.
lars
Been here awhile
NorCal flatlands
I assume it's the Dodge style NV4500. Actually I know it is, because I know what happened to the bell housing adapter you had for the 5.0 ;) I believe the 205 was used by Dodge for a while. In that case, if you get a Dodge 205 and a Ford 205, you should be able to mix n' match to get a bolt-on. Remove the input shaft assembly from the Dodge 205 (has 23 splines, same as your NV) and install it in the Ford case. From what I understand the general transmission to transfer case geometry is the same for all the big cases (the Dana 20 was an oddball) so then apart from possibly drilling/tapping some new bolt holes in the transfer case housing, it should bolt right up. Don't quote me on that, but I know that sort of thing works in other, similar applications.
M
Miley
Guest
Hey Lars!
Will these projects ever find resolution? For what it's worth, I certainly hope not. ;D
Thanks for the info on the NP205. I am going to heavily research that option. I'm going to cruise over to Pirate and see what I can find.
Jim
