well, I'm home from work now, and will check the things I mentioned along with the pcv valve idea, pull the plugs and check for oil, and maybe even a leak down test. I'd be shocked if he didn't prep the cylinder walls properly, I'm going to call him this evening as well.
The weird thing is, I've driven it for a couple of months now, mostly trips into town (8 miles), and haven't had to put much oil in it. There's no smoke at start up. Yesterday was the first time I took it to work, a coworked pulled in behind me and mentioned today that I had a lot of smoke at take off.
BTW, it's a completely new motor from oil pan to carb. It was basically turn key. It runs beautifully, and I finally got it timed so it doesn't ping. The same coworker that drove in behind me mentioned something about an additional seal needed on the oil rings on stroker motors. Is this right?
Thanks for all of the feedback guys, I've got my fingers crossed and will post later with what I find.
