How size should this bolt be?
brian72
Early Bronco Student
The bolt that goes thru the ps pump bracket and into the 302 block? size and length?
The bolts that hold the Thermostat Housing on?
size and lenght?
thanks
brian
airman
I have an old ford pump with the ugliest bracket ever from the PO. Its in a Home Depot bucket right now since I went to Saginaw. I was an ambitious man.
Are you mounting a ford or a saginaw? the threads in the heads will be 3/8" but it may be different depending on your pump and bracket.
brian72
brian72
I am running the oem bracket, same as in jeepsters pic, but have the napa pump. The other problem I see...The threads in the block are 1/2". What kind of mess do I have?
