OK, after using many compressors of friends, family and my own, I have a few feelings toward this issue.
Belt drive (slow compressor speeds) are good.
Direct drive is bad
Oil lubed is good
Oil-less is bad
Bigger is better in CFM, HP, gallons, stages.
The 2 worst compressors I ever delt with were oil-less direct drive units. They were so loud it would drive you out of the garage. Not sort of loud, but could not think straight loud. Could not run at night because is scared the neighbors loud.
Very light duty compressor. I picked up an oil lubed, direct drive 2ish gallon compressor for my brother. His air usage is next to nothing. The compressor is a little annoying at a higher pitch due to the direct drive, but the oil lube really helps with the overall dB rating. It works for airing up a tire, blowing out the water pipes, Impact wrench will cycle the compressor on at each trigger pull as if it were wired directly to the trigger. Good for a quick shot or low volume of air. Never would run a cut off wheel or die grinder.
Light duty. Oil lubed belt drive 20ish gallon portable. 2 piston, single stage. Light painting, mild die grinder (quick work, not porting), quick cut off wheel. Can be had in 110V or 220V. The 110V is good if you don't have 220V available. Also handy for portability.
Medium duty. I have been running a 60 gallon 5HP single stage compressor for years. Runs most everything fine. The 60 gallon tank lets you do a bit of work without getting into running the compressor. I have topped many tires and done a bunch of little jobs without the compressor ever cycling, just capicity of the tank. most are 220V, but a few are 110V. Very good for most any applications. The compressor is similer to the portable units but the storage capicity give you much more flexability. You can run tools that draw more then the compressor is rated for and usually get away with it due to the storage capicity of the tank. Just need to take a break every once and a while while the tank fills. But you will have time to actually take a break as it takes a while to fill the tank.
Bad boy. 2 stage 60 gallon. This is where the storage pressures start to climb. 175 is common instead of 120ish. The CFM is also up as well, ~50% above what you would find in a comperable HP single stage. This is for those who will sit down with a die grinder, set of ear plugs, some heads or manifolds and just port non-stop until the whole part is done. Fast recovery, moves lots of air.
Monster. Screw compressor. If you are shopping for one of these have deep pockets. Moves lots of air. Super quiet. can open a 3/8" air hose wide open and it can keep up. Dream compressor. Have some DEEP pockets for one! If you are considering one of these, you should be looking at a better resource then this site.
