how tall of jack stands do i need ??
broncojames
Smelterville ID
getting ready to order a 21/1 lift kit in the next month or two.
will be installing in driveway I have 6ton stands with 25 in lift height
how high do i need to lift of easy spring install ?
Skiddy
those should be fine, when you remove the tires you will have plenty of room
73stallion
Eugene, OR
can always build cribbing out of 2x4's with 2x6's on the top. i have a set mike (ScrapperMV) helped me build, work great. they're about 10" high and 14" square on the base. set the jack stands on top of them and they won't even sink in the dirt. more than tall enough to install a 3.5" lift.
let me know if you want pics.
muskrat
I did a 2.5" lift and used 6 ton stands also. I had to build wooden platforms for the two jack stands holding the frame up. then used another two jack stands to support the front diff.
Make sure you have plenty of beer.
rtj731
Head down to lowes-home depot.
For a few bucks pick up a 6x8x12 have them cut it up for into 14" pieces these will come in handy for all sorts of things.
B
broncojames
Smelterville ID
ok then that saves me a few buck's already have two sets .. any other info on installing the lift kit would be nice tips tricks ?????
thanks in advanced
James
cs_88
You just need one of these bad boys.
