How Thick for Carpet, Dynamat etc...
broncoitis
In the process of making an underseat storage area for the Passenger side of the Bronco and was wondering if anybody has a good guess as to how thick a combination of Carpet Dynamat or equivalent would be on the floor. I want the Storage area to remain flat across the whole floor and not have to shim it to get it that way hopefully.
I have basically 4" of height from the passenger side floorpan to the top of the step up. Don't wanna have to cut the carpet to get things lined up properly. So is 1/4" enough allowance or should I possibly allow 3/8" for the carpet and mat? Any thoughts would be appreciated. Gonna maybe get this metal cut tomorrow.
Hopefully this makes sense. %)
strokers
If you are going to lay carpet and dynamat on the whole floor wouldnt the carpet under the box be the same as the carpet on the floor next to the box?
Edit
If that is the case guess would still need measurement for how much to shrink box in lenght and width
Heus33
Dynamat is typically 44mil thick - 44 mil = 0.044 in
Not sure what the measurment is on the carpet 'squished down'
broncoitis
broncoitis
Thanks for the feedback guys and sorry for the crappy explanation. Basically don't wanna build the storage box and come to see that the Passenger side seat is HIGHER than the Driver side seat. That would be a PITA to fix and why I am asking this question.
Trying to look ahead and see any potential problems now and not after I build the thing! :eek: Tired of scratching my head and saying to myself, "How did I not think/forsee that!"
Steve83
Build the box perfectly level with the bare metal floor. Then put the same stuff on it that you put on the floor (mat, carpet) so they remain even.
But in Frank's truck, I built a base for a later Bronco passenger seat base, and that's his storage:
1967Bronco
I noticed your center console in your build. Any chance you could snap a pic of that and share more looks? It looks really clean and nice.
broncoitis
broncoitis
Nice job! Interesting idea for sure. Definitely took some time to get that done I would think. ;D
Steve83
It's not that difficult - just snag a '78-89 Bronco/F-series passenger captain's chair base, pull its long hinge pin, and then build a box that bolts to the eB floor & holds the pin & springs like the original FS base did.
