how tight?
fire bronc
iowa
How Tight Do You Tighten The Nuts Behind Hubs That Hold The Drum On. As Thight As I Can Get? Or Is There A Toruqe Spec.
broncnaz
For the inner nut torque to 50 ft lbs. then back off approximately 90 degrees
The outer nut is torqued 50-80 ft. lbs.
