YES! thats what I need. Now what is the bolt spacing measurement. And what style yoke does the Defender use(u-joint size) and could we adapt the yoke to fit on the driveshaft with a conversion u-joint? I wonder how deep that drum is? will we have to shorten our driveshafts? The Dana20 is as we all know uses a strap to hold it in the yoke, where that Defender setup requires a bolted flange setup like a 8.8 Ford or Toyota driveshaft. Im going to check Ebay for this defender setup probably pricey.
Tell you what, as long as it isn't raining tonight I'll crawl under my Range Rover and try to get some measurements for you. I'm sure you could get a shaft built to work with the Rover joints if you go that route, I may even have an extra yoke I could let you have if they are $$.
Here is some Land Rover U-Joint info from RangeRovers.net, confusing and expensive like all Rover crap.
U Joints:
Derek Brennan reports: Symptoms of failing U-Joints are high pitched squealing/ squeaking sounds coming from front passenger footwell, and drivetrain vibrations when accelerating from a stop on uneven surfaces. Replacement aftermarket U joints cost $60 each from Land Rover aftermarket suppliers. The OVLR site states that whereas UK and rest of world models without catalytic converters use Preciision 369 or equivalent u-joints, the ones on North American and other cat-equipped models are Precision 344 or equivalent -- the same as on a 1993 Volvo 240. This part also cross-references to PDQ1-0005 and Neapco 1-0005 -- the only difference is that the latter have the grease nipple in one of the bearing caps instead of in the middle of the "U" -- this makes no difference to function. Chris Wilson and Ron Beckett in Australia found that the U joints are the same as used on Australian Ford Falcons (not North American ones) and on the Volvo 240. The aftermarket part number used there is K5L4R. Derek found that Speedycarparts.com lists the correct U-Joint for $17.00 each, while Atlantic British and Rover’s North ask nearly $60 each. Derek purchased his at NAPA for $21 each plus tax. Partsamerica.com has another equivalent (GMB part number 2201100) for $11.99. I recently (December 2004) found U-joints said to fit the Range Rover Classic for $5.82 each at AutoPartsGIANT.com.
Here are some better shots of a Rover LT-230 transfer case, you can see the shoulder that the drum backing plate bolts to here.
Here is the back of the drum, there are a few different parts as some later model Range Rovers had a Borg Warner chain driven transfer case but the e-brake is very similar, if you do go this route you may want to source both parts and see which one fits best. I think the cable location and the index of the mounting bolts are the main differences. Hope this helps.
