----I'm starting to see what the issue is after looking at that link & several other places,, the pro rachet I have is different internally,, mine has no gate system at all the mechanism is purely racheting and always returns to center -no matter what gear I'm in from park ,reverse,nuetral & any forward the shifter is always in the exact same position,, for the reverse lockout when it was there you simply nudged it then it would lock & stay in position by itself while you racheted into reverse then spring back by itself,, the pro rachet forces you to use a racheting motion for every shift instead going through some gate system to get to reverse,, it's not like say the racheting quicksilver with a partial gate system which has to be in drive to get to reverse-is the mega shifter like that? ,, in stock form the pro rachet will allow free racheting from park to reverse but when racheting up from drive(or first if it's a reverse valve body) it's stop after you rachet into nuetral then you have to reach over & nudge the lockout lever into positon then it allows shifting to reverse from the nuetral position & the lockout lever springs back by itself into position for the cycle to repeat----about the going into reverse thing at speed ,,, I have mine mounted backwards because the pro rachet only comes in forward exit cable version ,but the way mine is bolted to the dash I needed a rear exit,, anyway this has cause me more than once to forget which vehicle I was in & rachet into nuetral instead of downshifting as intended ,,when this happens you are back to being alert very quickly & surely will not repeat the same motion you just did a few seconds ago
http://pirate4x4.com/forum/showthread.php?t=363036---- edit.-link added that's talks about disabling the pro rachet without removing anything like I did & by simply moving the lockout lever on it slightly forward then tack welding it-- it seems the pro rachet is the most friendly towards reverse lockout removal thing with its full racheting motion
