I'm in the process of installing a Blackbox-i and I need to remove the D20 input shaft. See the pic. Do I need to remove the rear output shaft assembly to pull the input shaft out from the inside? Or will it come out as is? I have not pulled on it too hard yet and I don't want to pull the output shaft assembly if I don't need to. It was just resealed by the tranny shop!
Thanks!
Thanks!
