Howell efi
bohntr28
Mesa
I am wanting to put an efi system on my Bronco. I have seen a lot of 5.0 conversions but think it may be beyond my ability. Has anyone tried the Howell or Edelbrock conversions? I am strongly considering the Howell. Does anyone have any feedback?
S/C-HD2002
CO
A friend of mine has the Howell injection on his '74. He has a mild built 302 with a cam and headers and it seems to run extremely well. It always fires right up and never missed a beat when wheeling. I also have never heard him say he wishes he would have gone a different route.
HTH
mountainview68
yet to be determined
I ran a Howell System on my last bronco for a while. Sytem was not to bad to put on, but really was not much more than a glorified carb. Ran a little rough when I changed elevation. Also took about 10 computer chips to finally dial it in. It is a speed density system. I would go Mass air if it was me. THere is so much info on how to do it, plus guys on this site are always ready to lend a hand.
720Racer
Auburn
I put a Howell kit on my GF's j**p last spring. I'm no master mechanic, and I thought it was pretty straight forward to install. (I did struggle with the part about "remove these 4 wires from the harness, and cut the rest off"--WHAT? I couldn't do it!) I also put a Davis Unified Ignition while it was apart. We are real happy with how it runs. I thought the technical support was good, and the instructions covered everything. To make things even sweeter, the j**p passed smog on the first try (I don't think the tech noticed the DUI).
Now, as for your aplication. I bought a 21K mile 99' explorer 5.0 complete for quite a bit less than I spent on the Howell and DUI. This will definatley take more technical attention on my part than the Howell, but I'll have a better motor for the extra effort.
Hope that's helpfull,
Galen
maverickconner
I also looked at putting a Howell on my 351w, just for cost sake, but it ended up being cheaper to piece together a GT-40 setup. There are enough write ups online that the 5.0 conversion is pretty simple when you start researching it....if your worried about the wiring, just buy one of Ryan's, do not go painless, what a pain in the +ss.
74bronc
I have installed about 6 Howell EFI systems on Broncos, Jeeps and Dodge products and they all ran fantastic. The GM throttle body injection system is dead reliable and runs well, but whoever said it is glorified carburetion was right. I would do it in a heartbeat on my truck if it were higher on my priority list. Good luck with your choice. If you want more info, just ask some specific questions.
rubiconbronco
Placerville, CA
i run a howell tbi.. been running strong for 6+ years. i have the complete chevrolet system on my 351w. howell could not offer much assistance at the time i did the conversion, becuase he never did a hydrid system like that on a ford back then.. the message above is right about the glorified carb(if you get the basic tbi system). its only worth it if you get the full computer controled system. then the computer will adjust your timing and fuel for various driving conditions..
SaddleUp
Vancouver, WA
If you do a comparison the Ford EFI is really not that much more difficult to do and you will have a great and proven Multi Port injection system when your finished. It really only gets difficult if you decide to sort out the wiring yourself and that just requires the ability to follow a wiring diagram.
Buckin74
San Diego
Don't forget about the "Edelbrock Pro Flow" EFI direct injection ---- It is a very well built unit with lots of room for onboard adjustments.
Steve
Grand Junction, CO
I have a Howell on my 302. I bought it used (along with a motor, C4 and Atlas) out of a comp buggy. Performance? I love it. Ease of install? Mine was harder since it had already been installed in another vehicle. However, you can download instructions from their web site. I had to call them a few times, and even tho I didn't buy it from them, they went out of their way to answer my questions and help me. Not sure that's the way I'd go if I had to buy the system new, but for the price I paid it can't be beat. :)
Glorified carb? Well, I guess if you consider a throttle body with injectors the same as a carb. %) Other than looking somewhat the same, there's nothing at all similar in how they operate, and there's nothing similar about how they perform at varying altitudes or on extreme angles.
