I'm wondering if you can run hard lines for high and low pressure, to and from the pump to the booster. I know you dont need the high pressure hose for the return, but do you need the high pressure hoses or can you run hard lines (steel)?? My set consists of a booster from a '97 F350, master cylinder out of a dodge, steering pump with duel return out of a mid '70 ford wagon, bracket out of a ford van modified to swing away from the top of the steering box. Any help is appreciated!
