Randy - also look at the Camaro master cylinder on Paul's site for disc/drum setups too.
Todd Z.
The Camero is looking like the better option.
This MC comes on just about every Chevy made from the late 60's to 1980.
Cheap too...
MC36306 - 1.125” BORE
GM Camaro Style Master Cylinder
* 1.125” Bore Disc / Drum Spec
* 1/2-20 Front Port – 9/16-18 Rear Port
* 65 / 35 Nominal Front to Rear Output Bias
* Residual pressure valve equipped for use with front disc / rear drum brakes
* 3.400 GM Spec Stud Spacing with 3/8” Bolt Holes
* Features a .250” MC pushrod hole for use with power brake only
* Front Port = Front Brakes / Rear Port = Rear Brakes
* Conventional flare style ports – brake line tube nuts included with MC
