hydro brake booster
rubberneck
Severn, Maryland
found a brake booster off an old continental, need to clean it up and install it.
I was looking thru some member's pics and saw the same hydro booster, except he had the power brake booster bracket on still. it set the hydro boost over the wheel well. it looked good. and it seems like it'll be easier to modify the rod, and adjust it. especially if using a turn-buckle.
no one (duff, wild horses, tom's) shows it installed like this. they all just rotate the hydro boost so the reservior is on the drivers side.
think there are any pros/cons to using the bracket?
talk amungst yourselves
SaddleUp
Vancouver, WA
Duffs sells a hydroboost bracket that goes over the wheel well. http://www.jamesduff.com/newproducts/new_eb.html
Personally I like the way mine (Off about a 99 Powerstroke) bolted right up by just drilling 4 holes. I didn't even have to adjust the rod and mine isn't flipped over. If you do flop them over so the accumulator is on the opposite side be sure to slot the bottom where the master cylinder mates to it for drainage in case the master cylinder leaks. (Match the slot that is there already since that is what it is for) If you don't then a leaking master cylinder will ruin the booster. Don't get me wrong though as I am already aware that the way mine is bolted up isn't going to work for some others. For many it could hit the EFI intake or the tranny shift linkage. My EFI intake is on the other side though and I have a cable operated tranny shifter so there wasn't anything in the way on mine. It did free up a big spot on my fender though when I pulled the vacuum booster bracket off.
Madgyver
Bronco Madman
Here is a pic of it installed without the stock bracket and the MC over the fenderwell.
crawln68
I have the unit off of an 84 Lincoln Continental with the Duff bracket over the fender. It works out very nice and keep it out of the way.
SaddleUp
Vancouver, WA
Hey, That bracket looks familiar. ;) Kind of looks like the one I pulled off mine when I put my hydroboost in. ;D
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
I have one off a Mercury and it was a 4 hole bolt up. This unit is the same as the Lincoln setup. As Saddleup says a straight bolt up for a 302 carbed install first 2 pictures show this with the Lincoln booster. If you have a 351 or a EFI setup it is easier and cheaper (no cost) to alter the mounting bracket under the dash and physically move the brake assembly over 3 inchs and use the wide pedal from the big car. Second 2 pictures show these. This is not a difficult modification the last photos show the wider pedal installed. Have a look and if you have questions let me know.
TOFIC
crawln68
I thought you might recognise that. ;) I had to weld an extra tab onto it to match the four bolt pattern of the hyroboost unit before I painted it. It worked like charm.
SaddleUp
Vancouver, WA
Glad it worked out. I was considering using it myself but mine bolted up so nice straight to the firewall that I didn't. I have so much junk under the hood it was nice to free up the extra space. I just need to figure out how to mount everything in now with the inner fenders removed.
crawln68
Inner fenderers removed!? Where you over heating?
SaddleUp
Vancouver, WA
Not really. Mine were getting pretty shot and were a bit beat up any way to fit the power steering, exhaust, etc. The extra room removing them makes to get around the engine will be nice as well. Having it run a bit cooler on the freeway will be a plus though. (Mine does warm up a little at freeway speeds because of how much stuff I have blocking the front) The reason I chose now to do it is because I had a bolt pull through the frame on my steering box. I figured it would be easier to get in and plate the frame with it removed. It took me 2 hours yesterday to actually do the plating since I had easy access to it. Now I just need to figure out the mounting for the stuff that's hanging. After that I need to replace my ball joints and my water pump and I'll be ready to go wheeling again. (Last time I went out both were already bad so I was already pushing it)
Mark
Bronco Klutz
NW Indiana
JDuff sells this bracket seperately also
rubberneck
rubberneck
Severn, Maryland
hydro clutch?
where'd you get that clutch. I'd like to see a tech article on that. looks really clean
